Tire Wear
Old Jul 16, 2011 | 06:44 PM
tarasgrosh's Avatar
Default Tire Wear
Hey everyone, I want to raise awareness about INSIDE WALL TIRE WEAR. Whether this is a problem amongst all Audis, or reserved for the A8/S8, it is worth noting. I recently replaced my tires and noticed that the inside walls were heavily chewed up, in comparison to the still salvageable outside walls.
Tire technician explained that "Audi's, apart from being AWD are set more aggressively..." Truth or lies, you be the judge, but I don't want anyone having an unexplained blow out.
Enjoy summer!
Old Jul 16, 2011 | 06:49 PM
mishar's Avatar
Tech Guru
Go for wheel alignment. Choose another shop. That one has poor technicians.
Old Jul 16, 2011 | 10:50 PM
Brozee's Avatar
Def your alignment buddy. My outside seemed to go a lot faster than the center or inner of my tire.
Old Jul 17, 2011 | 08:22 AM
EHLO's Avatar
Enjoy summer!
Inside wall, meaning the vertical surface closest to the engine?
Like the OP, I see the outer horizontal surface of the tire wear quicker.
Old Jul 17, 2011 | 08:56 AM
mishar's Avatar
Tech Guru
Wheel alignment ASAP. Before it suspension bushings should be checked. Good alignment shop would do that anyways.
Old Jul 17, 2011 | 11:13 AM
tashakes's Avatar
I replaced all 4 tires 8K miles ago. My fronts are still like new, my rears are completely gone, I already got the replacements.
BUT, they wore out completely even, perfectly flat. The issue you have is bad camber adjustment. The issue I have is bad toe-in adjustment, that is why my rears wore so much more quicker and completely even. I will have it realigned when I replace the tires.
Old Jul 17, 2011 | 12:00 PM
gaspasser19's Avatar
I replaced all 4 tires at 25K miles with very even wear across the tread. Get a new shop!
DerAudiA4
Aug 5, 2005 07:40 PM
C-Nutts
Wheels & Tires Discussion
Dec 10, 2003 02:23 PM
Dommi3
Jun 27, 2003 05:40 PM
