Charging Alternator Issue..Need Master Advice
batt management sys in it,vag it in eng and ck channel #4 to see what the
alt is putting out,rev engine with the lites on and ck output,13.50 and
higher alt is good,heat will kill a batt and age,
hope that helps,
DAN B.
Of course it's easier to first substitute a known good battery and then see if it loses charge, again provided you're assured the alternator is ok.
when you get the reading, is it with light on, a/c on?
13.4 and above with the alternator you have is ok with the lights and a/c on at idle.
the alternator you have is a water cooled Hitachi with an output of 190 amps, I have not replace one in an A8 yet.
never replace an alternator on the A8s yet.
may have to do with the battery management unit in the Touareg/Q7/Cayenne, on which I seen more than a few failures.
