Slime A8 suspension
1. After u put the car in Jack mode...do you put the car jack under the actual suspension ie. wishbone, or did u put the car jack under an actual jacking point.
2. Did u put the slime in the hose or in in the actual suspension?
Not sure, but you don't seem like you know enough about it yourself to just attempt it. Worst case scenario you could screw up a lot more than what is currently not working.
Take pictures and make a write-up if you do go through with it.
I think you may have to find the leak the hard way or you will possible ruin the unit entirely - I cannot imagine what the slime will do to the unit as it starts to set!
I'm going by previous post that showed it worked. See below
I thiAs another follow-up. It's been a couple of weeks now and my A8 suspension is working fine. My Allroad has been on Slime for well over a year now...
I placed the suspension in Jack mode, then using the car's hand jack jacked up the suspension up enough to gain easy access to the top of the spring. Then pulled right front air sping line off (pretty easy with a 10mm open-end wrench)and shot the Slim in. Replaced the fitting, lowered the car, the deflated spring will bottom out. Then started the car and put the suspension in Standard mode and the spring came up a usual. Finally I kook the car out for a drive on varied roads just to work the Slime in.
It seems reasonable that when these springs leak that the failure occures at the bottom of the unit where bladder is pushing/rubbing/rolling against the metal base. Natually the Slime settles down down to the bottom and does its thing. I doubt seriously that the system ever vents air from a spring fast enough to carry any of the Slime out, besides the air fitting is at the top of spring, the Slime of course settles at the bottom. Also if the leak formed elseshere, say the top or sides I doubt the strategy would work very well.
Don
Don
Audi 2004 A8L
Audi 2001 Allroad
Just make sure none can get back into the line as the unit is loaded up again and displaces air back into the pipework.
Unless you know what you're doing, you can do more damage that what has already occured. Fine if you bugger the strut (as it needs replacing anyway by the sounds of it), but if it get's in the lines...
Much cheaper than replacing the strut tho!
i know this is high risk manouver but I've got nothing to lose in my case.
I just cant swing the repair bills right now.
