Audi S8 Oil Change, Castrol 10w-60
Old Aug 4, 2011 | 12:16 AM
AmoKK's Avatar
Default Audi S8 Oil Change, Castrol 10w-60
Anyone tried this Castrol 10w-60? Is it ok to use it in my 5.2 FSI engine?
I've read that some guys were using 10w-60 on a few FSI engine for a while and got very positive results, lower oil consumption by a lot and hardly any carbon in the intake runners and intake valves.
Old Aug 4, 2011 | 07:39 AM
MP4.2+6.0's Avatar
Tech Guru
Default Haven't heard it for Audi motors, but...
is that the general oil spec being used with the last gen BMW M5/M6's (i.e. their pumped up V10) ? If so, that's an obvious clue. Don't know if that is a direct injection motor though.
Old Aug 4, 2011 | 07:29 PM
mishar's Avatar
Tech Guru
60 is too high viscosity.
Old Jun 6, 2022 | 02:14 PM
Fouraquest's Avatar
What makes it too high relative to the 40W Audi specs for our engines? The v10 lambo of the same era (granted, not EXACTLY the same engine) runs 60W oil. I've always though 30-40W oil is recommended for "normal" cars since its cheaper and easier to find at jiffy lubes and other oil shops. I struggle to believe that running a 60W oil in a 500HP V10 is going to do any harm.
Old Jun 7, 2022 | 12:04 AM
maxandtara's Avatar
Fouraquest,
I just came across the 60W oil. I never knew it existed. I have the same questions as you do.
Are you asking the question in general?
If you don't know, Mishar is in no position to answer any questions.
Old Jun 7, 2022 | 01:07 AM
JulianHicks's Avatar
There should be no reason why you use viscosity as a guide to Engine oil. The S8, like other A8s, simply requires oil meeting the VAG 504 00 spec.
Old Jun 7, 2022 | 04:04 AM
Fouraquest's Avatar
asking in general, but i also want Mishars reasoning for saying its not the right viscosity.
the problem with any of the oil specs is that they more or less have a standard viscosity assumption. for example, SAE 5W30 has the same specs as VW503/504.
60W oil shouldn't be an issue if the engine is given enough time to warm up before driving, but is it really that important it meets the VW spec?
Old Jun 7, 2022 | 07:28 AM
MP4.2+6.0's Avatar
Tech Guru
Misha unfortunately passed away--more than five years ago now. In archives.
Oil spec for D3 era was 502/505 in general. W12 was 503 in the tech documentation, but in practice was serviced in at least USA as 502. 504 came later, and is more or less a successor to 503. 502 still quoted as a spec and a variety of oils on market meet that spec. The 504 oils are more common in Europe; in USA often marked as "ESP".
Bottom line, widespread advice is use an oil at or above the spec in the given manual and at those viscosities. If it says 502, then 502 or 504.
D3 S8 (or C6 S6) motor is not same as R8 or Lambo motor BTW--particularly in crank set up.
When I have used heavy viscosity oils out of spec, it is typically because I have an oil burning issue and repair is not practical due to age/expense/unrepairable problem, etc. But more important there can be the rated cold temp viscosity (the "10" in this case). D3 S8's in particular seem beset by more oil issues, commonly physical leaks that viscosity is not going to help.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 7, 2022 | 10:11 AM
Fouraquest's Avatar
I did not know that. I'm glad he's archived in here for us.
I'm interested in exploring the performance differences between those viscosities. I do indeed have a leak at the moment, only slight, but that is not part of my rationale for moving to a different oil.
Old Jun 7, 2022 | 10:16 PM
MP4.2+6.0's Avatar
Tech Guru
See below. Not even a close call to me, like by a mile. Whether older 502 or newer 504, at least a little to think about, but seems to me pecking order clear. 501<502<504.
Graphical model: https://online.lubrizol.com/relperftool/pc.html Make sure pop up blockers are off or you can't access pull down menu needed to generate the plots.
