Knee Airbag
Old Aug 7, 2011 | 09:38 PM
Quattro_#2's Avatar
Default Knee Airbag
I've had this code thrown for about a month now. I posted it in the VAG-COM section and they told me this is a dealer concern. Reading through some of the posts here about airbag fixes I'm tempted to try the cleaning of the connectors trick to clear this code. What do you think? I've never done it before but technically inclined. Just don't want it going off if I complete a circuit. All help is appreciated thanks.
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Shop #: WSC 02313 785 00200
VCID: 244D19D89E4B
1 Fault Found:
01742 - Igniter for Knee Airbag; Drivers Side (N295)
001 - Upper Limit Exceeded - MIL ON
Old Aug 8, 2011 | 08:05 PM
A8nightmare's Avatar
[QUOTE=A8nightmare;24181115]Clean them off and reconnect. I have had two with the exact same code, but rear bags with the same high limit code etc... The pin connectors are very small and tend to get loose,dirty,moisture etcc...... The connector is a small two pin connector with maybe 18-20gauge wires going to it. I have just wiped the male pins down with a contact cleaner and then wiped with WD-40. You will not set the airbags off by doing this. One of the master techs recommended a better contact spray. You can go to radio shack or an electrical supply house to get a better moisture/contact spray.
Old Mar 10, 2012 | 09:22 AM
K9COP's Avatar
Default I know this is an old post, sorry, but,
My car is giving these codes, do you think it could be the same problem? :
Coding: 0530707
VCID: 244DDDF3E7C0DE3
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Thanks,
K9
[QUOTE=A8nightmare;24181119]
Old Mar 10, 2012 | 10:01 AM
mishar's Avatar
Tech Guru
I think it is the same problem. Few drops of DeoxIT will cure it.
Old Mar 27, 2016 | 03:54 PM
Divyesh Patel's Avatar
Default Knee Airbag Ignitor Upper limit reached
Hi Guys,
Does anyone know the location of the connector needs cleaning to try seeing if it resolves error code 01742 ?
Old Mar 27, 2016 | 04:42 PM
dvs_dave's Avatar
AudiWorld Wiseguy
You'll need to remove the lower trim panel (which the airbag is part of) to get to the connector.
Search "air compressor relay" topics on how to get the panel off as its not obvious how to do it. Or refer to a workshop manual like Alldata, Elsawin or Bentley. A purchase or subscription to the first two is well worth it as they're not expensive.
Old Mar 27, 2016 | 06:10 PM
TSHong's Avatar
+1 on the Deoxit. I fixed my airbag light with it.
Old Mar 27, 2016 | 09:03 PM
MP4.2+6.0's Avatar
Tech Guru
FWIW, I think you guys are all barking up the wrong airbag here. For the poster asking question early today, do a search and make sure you know where airbag N250 is. This is not it AFAIK.
Expect to invest some time, and I can preview you are going to get into some multiple step disassembly involving some fragile parts. You need Bentley or one of the on line or other manuals. Given that, probably want to be sure you are up to speed on safety instructions on working on them, like disconnecting battery.
You will actually be putting this piece aside relatively early BTW so know how to deal with it as well.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 28, 2016 | 11:44 AM
Hello,
Do you think N250 airbag is the right place to check for this error code?
01742: Ignitor for knee Airbag Drivers Side (N295) upper limit reached
Old Mar 28, 2016 | 11:46 AM
Hi TSHONG,
Based on what I read on this thread it seems like i should try cleaning the igniter connector. But the issue is I dont know where is it located. Any help locating the igniter connector (probably a picture) would really be appreciated.
