How to change fog light bulbs (2008)?
All that said, I cannot find anywhere what posts or forum(s) I was reading that lead me to this bulb, nor can I figure out with certainty how to change the bulb. I took off the lower grille this morning and see the fog housing, but not sure if I need to unscrew and pull outward or what.
Can anybody tell me how to replace fog light bulbs? Thanks in advance.
P.S. '04-'05 and maybe '06 A8s use H11 Bulbs and not H7! I ordered the Osram Super Brights and had to send them back, but you should be ok with an '08.
Grilles just pull off by hand though. The passenger side bulb can be pulled by just reaching through where the grille was. On the driver side (S8) there's too much in the way to do that but I was able to get my hand in between two attachment points where the lower part of the front spoiler meets the plastic plate at the underside of the car and get the bulb in/out that way. No tools are necessary if you can get your hands in there - you are just accessing the bulb from the back and are not messing with the light housing at all.
