Squeaking sound from suspension
Old Aug 16, 2011 | 03:59 PM
05SilverA8's Avatar
Default Squeaking sound from suspension
I am sure other have been through this; When I make a sweeping turn I get a squeaking sound from the suspension. I had upper control arm bushing replaced recently, so I doubt this is the cause. Does the sway arm bushing make this type of noise? Any other suggestions on where to look?
Old Aug 16, 2011 | 09:12 PM
mishar's Avatar
Tech Guru
I don't have experience with sway bar links (yet) but I read here that they can make similar sound as upper link bushes. Some silicon oil spray might help.
Old Aug 17, 2011 | 08:30 AM
MP4.2+6.0's Avatar
Tech Guru
Default +1 on sway bar bushings; also links
Yes the sway bushings can make noise; haven't seen it on my Audis in years w/ OEM bars. Did run into it with an H-Sport aftermarket bar on my C5.
You might also look at the front sway bar links--the horseshoe shaped aluminum piece with the bushings to which the sway bar ends are bolted. After the front upper A arms, probably among the other most common wear areas in the general suspension design seen in D3 and other Audis since late 90's. Easy to change. Probably a part more likely to get sloppy than to squeak.
BTW, not clear if squeaking happens under all conditions. If so, we're all on the right track. If it varies w/ temp or is primarily right after you (the OP) first start driving, you have to consider the air strut units.
Old Aug 17, 2011 | 12:32 PM
05SilverA8's Avatar
Squeaking occurs just on more sweeping corners on occasion. A very loud sound emanates in the cabin and it only lasts a second or two.
Old Aug 17, 2011 | 04:55 PM
mishar's Avatar
Tech Guru
A second or two of very loud continuous sound? I wouldn't say it comes from suspension. Could it come from your brake? Floating calipers sometimes make funny sounds when wheel is under lateral stress. Try to touch brake pedal when you hear it (or expect it).
Old Aug 18, 2011 | 12:51 AM
A8nightmare's Avatar
The sway bar links are most likely the problem, but the other thing that can cause that creaking groaning noise can be where the sway bar is mounted to the car. There ar two points with rubber bushings that mount it. As it twists the rubber may be dry and will cause the noise. Check that out first.
Old Aug 18, 2011 | 03:15 PM
05SilverA8's Avatar
It definitely is a loud "Squeak". It only happens on a left hand turn and sounds like it is coming from suspension. I will check out sway bar components first.
Old Aug 18, 2011 | 03:20 PM
A lot of times you can have someone turn the steering wheel when parked and you can actually hear and see the creaking sway bar links. They are completely visible without lifting the car. I would try that as well.
Good Luck!!
 Pouria Savadkouei
 Michael S. Palmer
blazej01
Nov 6, 2017 06:54 PM
Greg5OH
30
Dec 24, 2016 12:01 PM
Torsion'sA8
12
Aug 9, 2016 10:38 AM
zarmstrong92
A6 (C7 Platform) Discussion
Jun 8, 2016 07:28 PM
Henrijs
Nov 14, 2014 12:28 AM
