Trunk Issue
I'll try cleaning the weather stripping. Maybe the rubber treatment I put on it when I purchased the car has gotten sticky, but have others had a trunk the works fine, but stick when opening? If so, what was the cause?
I've read that trunk issues are common, but most seem to be with hinges or motors and the motor is still running and the hinges seem fine.
There are other products that work well too. But everyone seems to have WD-40 in their toolbox. Give it a try.
Good luck
Good luck
However, I think I know what the problem is. After I posted, I cleaned the gasket and ran the trunk up and down. It wouldn't go up without help, but I noticed it went down too fast toward the end so I tested the hydraulic lifters and the right side is much weaker than the left. This would explain why the system still works, but needs assistance going up and is too fast coming down.
Good luck
I've been having same issue as enGage recently and water and soap haven't helped.
Suspect a person who allegedly helped me with groceries by ripping the trunk open may have not helped the situation.
I'll know tomorrow if that is my issue, when I pick up a new one, but it sure seems to fit the symptoms.
It tries hard then the trunk just flops down unless you give it a nudge.
Nothing seems to be out of alignment or sticking as far as the mechanism goes.
Keep us posted.
Hinges are all aluminum an as flimsy as possible. They would bend and touch lifters. It will make a mark on plastic wire holder. If that is a case just pool them to the side of a car using players or just your hand.
Lubricating is regular maintenance but it will not help here.
Used the trunk during my lunch 5 minutes today and it is not rubbing the wire holder or anything else.
