S8 D3 'Flapper mod'
Old Aug 31, 2011 | 06:04 AM
phil612's Avatar
Default S8 D3 'Flapper mod'
Hi all,
I've been researching doing the exhaust 'flapper mod' to my S8, for the uninitiated this basically means forcing (or tricking) the two flaps in either muffler to stay open all the time. From what I've read all I (should) need to do is block the vacuum pipe which feeds the piston valve on each of the mufflers, I'm thinking of doing this with a small clamp. Has anyone else successfully achieved this on an S8?
Thanks in advance!
Old Sep 3, 2011 | 08:44 PM
MP4.2+6.0's Avatar
Tech Guru
Default Same as W12 set up; net you can just pull the vacuum lines
The valves "fail" to the open position without vacuum. Thus just pulling the hoses opens the valves permanently. The hoses don't seem to be tied to any CEL warning issue either, though it's simple just to plug the hose end.
I tried this on the W12 and it did increase the exhaust noise a bit, and w/ out other issues of any note. But, I ended up putting it back to stock, figuring on an NA engine, greater back pressure (ie. flaps closed in lower RPM range) typically increases torque. Presumably among the reasons the factory set it up that way.
Old Sep 4, 2011 | 02:25 PM
EHLO's Avatar
On the S8 they fail closed without vacuum.
I toyed with the idea of installing a switch that I could use to toggle the opening, but ended up cutting eyelet brackets into more of a C shape, and pinned the valve arm to the open position by bolting the machine threaded end through a hole in a nearby bracket.
I'll add a picture tomorrow.
AuditudeRS4
RS4 (B7 Platform) Discussion
Dec 5, 2007 06:03 AM
Tourette(AFC2.812v)
12v V6 Discussion
9
Nov 2, 2005 01:45 PM
Funrevn
Jan 9, 2005 10:11 AM
TToro 3.2
Mar 7, 2004 06:42 PM
nurseman
12v V6 Discussion
10
Oct 20, 2003 06:40 PM
