FYI...D4 S8 Just Revealed---520hp 4.0L Twin-Turbo V8
I also suspect it produces 420 hp the same way the S4 produces 333hp. Totally under rated just for marketing purposes. Just so it slots where they want it on paper. Probably closer to 500hp in reality.
Thanks.
http://www.fourtitude.com/news/publi...le_7153.shtml;
The difference in power output between the two versions of the 4.0 TFSI is due mainly to the use of either a single-branch or dual-branch intake system, the turbocharger operating settings and the top version’s additional oil cooler. There are further differences relating to the crankshaft and its main bearings, the compression ratio, valve timing and the injectors.
