Fuel filter change procedure for 4.2 tdi
I know all you US folks are going to say tough luck because you do not have the TDi's over there yet, but I am hoping that someone may just have the procedure.
I have to change the front brake pads and do an oil change as well and all the same jobs on my wife's Touareg as well - busy weekend I think.....
to prime it just fill it with diesel or use ATF (automatic transmission fluid) the red color one like in old cars, this helps keep seals flexible inside the pump/s and cleans the injectors.
S4: I currently have E3 spark plugs and I see no gain/difference from when I had the stock plugs. I am nearing 100k so I believe that it is time to change them out again. I was thinking the NGK Platinum plugs. Comments/suggestions? Thanks
those and other fancy plugs have been tested by popular mechanics with very disappointing results, not even 1% gain, and those tests were made on cars that use crappy plugs to begin with.
remember these cars are running at the edge of the latest technology available and they are superior at every angle without sparing cost for the best performance.
I see problems with some or all of these "marvelous" plugs where they can't handle the heat generated by the extreme high voltage ignition systems generate this cars generate and the housing contract a lot causing the threads to come loose and vibrate damaging the threads.
specially on turbo engines we replace a few cylinder heads due to the spark plug pulling the threads when they became loose due to contraction of the plug.
I was an NGK convert from Bosch on earlier Audi's where NGK innovated with copper core plugs and Bosch was still stuck in an earlier era, but that was years on and we are now at the Platinum/Iridium changeover and debate era. Both plugs (in OEM fitments) are now well regarded.
