Need help...Found some 18" S5 Rims with
That said, if it's an absolute killer deal it might be something to consider.
Many of us here have priced wheels lately and they aren't cheap at all.
My 2¢
Offset is OK. Wheels would be 14mm further apart. That's acceptable.
In any case, I am under the impression A5/S5 wheels are not a direct bolt up to the long running 5 bolt hub the D3 has. To make it work, you would need/want some kind of hubcentric insert, or more likely some kind of spacer/adapter; don't know if one is made like that.
Center bore fix.
At the end it's your call. I would pass.
