rear door trim/card removal
Old Sep 5, 2011 | 05:55 AM
madbaz's Avatar
Default rear door trim/card removal
hello got a early d3 03 plate a8 quttaro and my speeker grill on rear door is cracked and need to remove the read door card but dont know how all i know is there is 3 or 4 bolts and clips i have located 2 bold 1 behind tweeter grill and 1 behind the pull out door pocket but unsure of the rest iv been told there is a bold behind the wood trim but when i took it off there was none so any help would be great
Old Sep 5, 2011 | 07:55 AM
mishar's Avatar
Tech Guru
Welcome!
Will this help?
Old Sep 5, 2011 | 08:53 AM
madbaz's Avatar
sort of but when i removed the wood trim under window i dont have any no 4 bolts as shown in the diagram
Old Sep 5, 2011 | 11:06 AM
Hilden's Avatar
might be then that those bolts only are on car with rear door curtains then. I have those bolts and I also have the el. curtains in the door. but if you dont have it just remove the one behind the tweeter and pocket and try to snap out the door panel- you can also look for my DIY on the subject. I posted it a few weeks ago so can´t be too deep in the archives.
Old Sep 5, 2011 | 03:13 PM
madbaz's Avatar
yeah been that post i could be door cards with blinds have the extra bolts under trim but gonna try again tomoro gettin door card off
Old Sep 6, 2011 | 01:31 PM
Hilden's Avatar
yeah just snap it off around the side and lower edges, if you after that can´t just wiggle it upwards until if comes off there´s prob some more trick to it so don´t rip too hard. my guess thoguh is that if you have no bolts behind the trim it should just snap out around the edges and then lift off
Old Sep 6, 2011 | 03:12 PM
madbaz's Avatar
yeah it was just the 2 bolts and rest were clips but got it off in end no damage and replaced the broken grill even managed to reuse all clip as none were damaged thanx for all the help
Old Nov 13, 2011 | 07:16 AM
davidre's Avatar
Default Front Door removal diagram
This is a great post, thanks!
I was wondering if anyone has a 'front door' version of this diagram?
I'm trying to replace my front wing mirror (Audi quoted £230 + vat to fit).
If someone could post this, or point me in the right direction it would be much appreciated.
Thanks in advance!
Dave
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 13, 2011 | 09:45 AM
mishar's Avatar
Tech Guru
This is the right direction. Not that it is too difficult to snapshot few pages, photobucket them and post it here, but as you can see there is money to be saved doing things yourself and it is not really perfect to ask every time somebody to look into manual for you.
Old Nov 14, 2011 | 03:38 AM
davidre's Avatar
Thanks again - I will buy this, but was my car is currently in bits... I have the door card off and have taken off the mirror, but I cant seem to work out how to get the wire / connector through?
A panel must come off somewhere...
