have a multi-meter ? please tell me what...
Old Sep 12, 2011 | 08:41 PM
awdinut's Avatar
Default have a multi-meter ? please tell me what...
your battery voltage measures in the morning before the car has been started. Mine reads 12.2 V and that seems like a low amount, but I have nothing to compare to.
Old Sep 12, 2011 | 08:54 PM
mishar's Avatar
Tech Guru
It is definitely low.
Old Sep 12, 2011 | 09:30 PM
A8nightmare's Avatar
If you are just measuring the voltage off the battery without it running...than 12.2 would be normal. Heck your battery could be half dead and still read 12.2volts on a multimeter. When using a multimeter there is no load so it takes nothing to display the voltage, but if you had a load on it then it you see if your battery was bad. That's why they have load testers for batteries, because there is no real way to tell if a battery is going bad off just a voltage reading. You should check the voltage while the vehicle is running at least you could see if its charging.
Old Sep 13, 2011 | 04:08 PM
awdinut's Avatar
Default Did all that....
Prior to posting my question I took a multi-meter reading with the engine running...14V,so I know the alternator is charging. And had a load test performed on the battery...battery tested good (only a few months old).
Old Sep 13, 2011 | 04:38 PM
mishar's Avatar
Tech Guru
12.2V is still low. It should not go lower than 12.6V. Could it be that your multi-meter is not really accurate?
Old Sep 14, 2011 | 12:53 PM
awdinut's Avatar
Default so, tell me what's YOUR battery's voltage ...
Are you saying that before starting in the morning your's actually reads 12.6V ?
Old Sep 14, 2011 | 07:26 PM
mishar's Avatar
Tech Guru
Yes. That's what led acid batteries theory says. I was lazy to do it this morning but I will measure it tomorrow. My battery is not new but I believe it is still good.
Old Sep 15, 2011 | 01:23 PM
awdinut's Avatar
Default took my multi-meter to an electric calibration shop...
it reads 11.96V when connected to a calibration device that generates exactly 12V. So my meter is accurate for the purpose under discussion here.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 15, 2011 | 02:46 PM
mishar's Avatar
Tech Guru
Checked mine and it is also 12.2V. I hope that theory is wrong.
Old Sep 15, 2011 | 07:27 PM
awdinut's Avatar
Default thanks for measuring for me...
12.2 defies theory and reasoning, but if another member reports in with 12.2 also I'd say ours are normal.
