90Q wont start
Old Oct 9, 2011 | 07:30 PM
nlybarge's Avatar
Default 90Q wont start
So, my car has decided to not start. I checked the battery and it has good charge. I also only hear the fuel pump prime every couple of key turns. All of the lights dim when i try to crank as if the battery is dead. My first thought was the starter. But im wondering if i dont have a complete wiring cluster f*ck somewhere. I should mention that this is a 1990 90 quattro 20v, with a 10v motor swap. (I didnt do it and i dont know the person who did, i would b*tch slap them if i could)Also, when i turn the key to try and crank, the rpm gauge floats up sometimes. Any and all help is deeply appreciated.
Old Oct 9, 2011 | 08:05 PM
nlybarge's Avatar
Wow, i feel like a dumbass. I took the battery out to put on the trickle charger. (been having a battery drain issue, -different thread-) And i was in a hurry when i put it back in and just slid the terminals over the posts. So it wasnt starting because the it had a bad connection. . . so if you are having this problem, check your battery connections.
SOConnell
Dec 28, 2021 07:17 AM
jloktalGst
May 30, 2018 03:56 PM
Brady Miklos
Oct 3, 2016 06:52 PM
dang
18
Jun 8, 2008 04:21 PM
NattyDreadz
Nov 18, 2002 12:42 PM
