Sometimes it starts, sometimes it doesn't
So my daughter has a 2003 Audi A4 3.0 Quattro. She complained that every once in awhile the car wouldn't start, just click like it had a dead battery, but it didn't do it all the time. It would always start when jumped. She took the battery in to have it checked, supposedly A-OK. I looked at the connections, read the voltage from the alternator, everything looks fine. I figured maybe the start was week, and the extra amps provided with a jump was enough to kick it over. Anyway replaced the starter, car fired right up. Let it run a few minutes turned it off. Went back to start it, just clicked like a dead battery. Tried it about 4 or 5 times, then the starter began to turn the car over slowly, but enough to get it to start.
I'm open to suggestions at this point, so any help would be much appreciated.
If you have replaced the starter, and it always started when jumped, then I would try another battery. But, check the clamps carefully, and the battery ground connection. Also, I would put a voltmeter on the battery posts to see what happens when the starter only clicks. Full voltage, then the battery is not the issue. But if volts drop way down, likely an internal battery defect. One last thing; be certain that the click is coming from the starter and not some under dash relays. That would mean a different approach.
Good luck, I think you are just about to solve this. I wouldn't worry about the alternator at this point. If the charging voltage is too low, you will get a dash warning. But the Voltmeter/DMM is your friend here. With a good battery, the starter motor spins the 3.0 really fast, but you need to have low-resistance connections between the two. If, for instance, there is a voltage difference between the cylinder head and battery ground post when trying to start the engine, that would indicate a battery ground problem. Likewise, if you put a test wire on the battery lug at the starter motor, and the other meter probe on the battery + terminal, a Voltage over perhaps 1V when attempting to start would indicate a battery - to - starter cable issue.
Glad you have apparently solved your problem. For many stores like Autozone, "checking" the battery means putting a voltmeter on it. 12v="ok." But this is not the way to test a battery. You need to have a device that puts a load on it (aka a "toaster.") The readout will then be of the red-yellow-green variety.
audiringpwr
01-13-2004 09:38 AM
