ET32 OEM Y Spoke Rims on an A8L ?
Old Oct 15, 2011 | 08:18 PM
budkole's Avatar
Default ET32 OEM Y Spoke Rims on an A8L ?
Do you guys think these will fit on an 06 A8L with 255/40 19's ?
Old Oct 15, 2011 | 08:32 PM
budkole's Avatar
one more pic
Old Oct 15, 2011 | 08:44 PM
Brozee's Avatar
Yes. No reason as to why they wouldn't. Great looking rims btw.
Old Oct 15, 2011 | 08:51 PM
budkole's Avatar
My research has led me to believe they came from a s5/a5....I know the offset is et32, just wondering if they would rub because they are wider and something I read about the bore size being different. Not sure that makes sense to you.
Old Oct 16, 2011 | 08:42 AM
MP4.2+6.0's Avatar
Tech Guru
Default ??
If A5/S5 then yes, the hub center will be larger in those and you need at least an adapter ring for hubcentric mount.
You would need to say more about intended tire size as well as rim width (which will be stamped on them), but in very general terms that ET will push the rims outward in the fender well around 1/2." Essentially that would substitute for spacers if you want a more aggressive look, and be about the max you would want to do in front (where the likely spacer used is 12-15mm).
This is assuming the rims are at least 8 1/2" width (offsets and rim widths are interrelated when you look at how it fits relative to the fender location); if they are only 8" I probably would pass except for snow fitments. Also, think about wheel strength. If the wheels are from an A4/A5 type class, that is a meaningfully different weight and power car than an A8. S5 maybe--somewhat lighter, but until recently w/ a 4.2. By A6 it is in the same weight class in general, and if a 4.2 A6 then pretty similar power and torque.
Old Oct 16, 2011 | 11:10 AM
budkole's Avatar
thx for the info
coryj003
Jun 15, 2015 12:09 PM
mikesd1980
Oct 17, 2010 02:21 AM
borden
Nov 4, 2004 01:28 PM
Allroadfin
Audi allroad
13
Aug 19, 2004 08:13 AM
Shockwave
Wheels & Tires Discussion
May 10, 2000 09:11 AM
