Mangled coil pack boots, should I be surprised
It looks like the tech just jammed them down into the heads. 4 out of 8 where like this.
Admittedly, this is my first plug change, but it doesn't seem that hard to get these in straight—I would think a $100+ hour Audi tech could get it right.
Just a little shocked to see them in this kind of shape, that's all
I would agree if you tell me to apply some silicone spray at the boot and then slide them in.
I see torn boots even at first plug change, this coming from the factory.
but hardly 4 out of 8 though.
The hard ignition wire is a bit of a pain to work around, there is very little play. Other than that, just gently pull the coil packs out, and make sure you slip them back in straight. If you get it right, you'll hear an obvious "pop" as you make contact with the plug tips.
