B4 95 90 sedan w/AT....Reverse Lights on all the time..
Nope.
Some have said I have a bad Multi-Function switch on trans? :frustrated: Any help would be appreciated.when key is turned to ignition on. The trunk wiring is ok. Getting juice at connector on left-side bottom of trunk. Go to the front and locate (Blue/Red wire) for reverse lights at green connector behind knee panel on driver side. There is juice there at connector?! Can't seem to locate the Park/Neutral Relay that may be causing this problem. Where the hell is it? :frustrated: Some say on Aux. Panel & others say on Primary panel...Pulled fuse to see if it disables the Rev lights.
Nope.
This may or may not be what you have as they change wiring throughout the years.
This is what it should look like
http://www.pelicanparts.com/cgi-bin/...39%36%29%20%20
