Fuel leaking under pressure... HELP!
Old Nov 6, 2011 | 07:29 PM
Jettamethis's Avatar
Default Fuel leaking under pressure... HELP!
Hi there. New here and I need some help...
Need some options…
Girlfriend's 1993 Audi 90 CS @ 150,000 miles...
Engine wouldn't start for several days. Started checking battery, plugs… then ended up changing fuel filter (there was good change that the filter was never changed).
The car started up and I took it around the block. When I parked, I noticed a steady stream of fuel from the fuel tank area pouring onto the ground. I turned off the engine and after a few moments, the leaks settled down and stopped all together.
The leak doesn't seem to be coming from the filter. Is there a way to know where exactly the fuel is leaking from?
Old Nov 7, 2011 | 05:00 PM
Loudgoldwing's Avatar
Trace the fuel line up from the filter to the pump. You probably cracked the line or pulled it off of one of its fittings when you were wiggling the filter off/on.
acthad
Sep 1, 2008 04:25 AM
20VT90q
May 27, 2007 09:16 PM
SparTTan
Oct 6, 2004 07:32 AM
AlLueb
Audi 100 / A6 (C4 Platform)
Sep 17, 2004 06:45 AM
AlLueb
Aug 21, 2004 07:38 AM
