Oil leak from passenger side valve cover- cam seal?
I just got a 1993 90cs for my sister- it's the first Audi I've had experience with. It's a great car- to be honest, I was surprised, because I'm admittedly a BMW fan. I have a fair bit of experience (side-job) working on Bimmers, Land Rovers, and Mercedes, but VW/Audi is new to me.
Anyway, on to my question:
The 90cs is shockingly dry- it didn't have any leakage or seepage when we got it, but several days later it has sprung a considerably large leak on the passenger side of the engine. I traced it back to the rear of the valve cover- it's coming from a circular metal plate on the back, held in place by two bolts, probably about 3" in diameter.
Is this is a simple cam seal leak? Just pull the cover off and replace the seal?
Is the seal behind that black cap? If so, how do I remove it?
I feel a little bit dense here... I'm thinking the valve cover gasket was leaking too, but I'd like to replace the rear cam seal while I'm back here if there is such a thing.
Removed the old, cracked o-ring and replaced it with a new one (223mm?) and replaced the seemingly original valve cover gasket. Bone dry!
