Central Locking working pressure
My question is, does anyone know the working pressure of the system? I thought I might hook up an air line at 3 psi or so to help find the leak. Pull the line off the pump in the trunk and hook up my air line there.
Any thoughts?
Accessing the system at the rubber Y next to the pump, the Mity Vac acted like I had no hose hooked up at all. Which is how the system behaved; the trunk would lock, but the pump would time-out before the door locks moved either way. I measured the output of the pump when it was in push(blow)mode, and got approx 1-2psi. So I hooked up my little regulator that I use for pressure bleeding the brakes/clutch and put 1.5psi into the system.
I appreciate the risk, but when you have a parts car, you get brave with this sort of activity!
I heard the hissing near the pass door, pulled the panel and still couldn't find it. Turns out, there is a rubber Y under the pass side carpet that had come apart. I pushed the plastic tube back into the Y, and everything works as expected. I put a little glue on the tube for luck.
Bruch
Bruch
The wifes 90 has a problem with both the drivers side doors not locking with the vac system
Lift while wiggling to release it from metal spring clips.
The Y connector is under the carpet about 3 inches from the outer floor mat anchor post. You'll see vaious wires and tubes in a track under there. The Y connects the tube from under the back seat with the 2 doors on the passenger side. Be careful not to slice your arm open on theose metal clips.
BTW, the door locks open with pressure from the pump, and they lock using vaccuum from the same pump.
Tell us what you find.
