Option code question
Old Feb 7, 2012 | 09:21 AM
eejimm's Avatar
Default Option code question
New to Forum, already finding lots of info here - Impressive information and knowledgeable members, less flaming than I'm used to on other automotive forums.
Recently got an 01 A6 2.7t 6spd Quattro (my first Audi if you don't count a '76 Fox wagon from college days...) in remarkably good condition for 216K miles - PO had everything done by dealer up through last major service at 199K. Only major issues are brakes (parts on the way from DRT Sport) and an intermittent EGT 2 code (will be repairing the sensor box soon). Needs some help with paint chips, but I'll deal with that eventually. Drives fantastic - I really love turbos, and I was looking for one of these for a while. Got it at a real steal, too.
In researching things, I noticed it has the option code 1SA which decodes as "Without additional front underbody guard"
The car is missing the belly pan under the engine - I assumed someone just removed it. But the option code makes me wonder if the belly pan is the "front underbody guard" and it never had one - anybody know for sure?
Thanks,
Jim
Old Feb 7, 2012 | 01:00 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Interesting question.
http://www.jimellisaudiparts.com/ima.../247863250.jpg
Shows a second underbody noise insulation panel that I don't have on either of my 4.2 cars and
That I've never seen on a us model A6.
The URL ref. doesn't show a p/n either, but perhaps that second underbody panel is the one that isn't there...
Old Feb 7, 2012 | 01:15 PM
eejimm's Avatar
Default Now that you mention it...
...I do remember seeing that in a picture in the Elsa on-line manual too - has anybody ever seen that rear-ish cover in the real world? I don't remember seeing it in any pics of an A6 undercarriage, but then I've only been looking/thinking about this for a few weeks.
I wouldn't think that the belly-pan would have been optional since it's important to the aerodynamics => gas mileage of the car. Does anyone NOT have the 1SA option on your build sticker?
Jim
Old Feb 7, 2012 | 04:38 PM
jcman's Avatar
Default 1SA option....
Yes I do on my 2004 PR code sheet and I do have a belly pan if it helps.
Old Feb 7, 2012 | 06:04 PM
meternerd's Avatar
As far as I know, the "splash shield" is stock. Parts houses only show trhe one underbody pan. My 01 has one. I'm not so sure what an additional uderbody gozmo would be.
Old Feb 7, 2012 | 07:12 PM
Redneck Truck's Avatar
Maybe it's an actual skid plate for police vehicles or some other vehicles likely to encounter adverse terrain.
Old Feb 7, 2012 | 10:02 PM
MP4.2+6.0's Avatar
Tech Guru
Default I've seen that diagram too, but likewise...
my 2000 A6 4.2 has the normal front one only. It is required for aerodynamics, and in Europe likely also to get past noise requirements that are measured from outside with vehicle in motion. Also keeps the underhood area cleaner and likely helps force air through the radiator and other cooling panels up front.
My 2006 A8 does have a second panel behind the main one, with that front one in turn a bit shorter. It still doesn't reach back to the transmission pan area but gets close. The one further back seems to interact with channeling air that ducts in from the forward belly pan through several different auxiliary coolers that are down there--the W12 is loaded w/ them. To go with it there is a second mounting point further back, with the rear of the front belly pan sharing its mounting area w/ the leading edge of the second pan starting right at its rear edge (side by side, not overlapping). My C5 just doesn't have those kind of expected mounting points back there; would need further brackets and not clear what they would really mount to.
gustavorlc
A6 (C7 Platform) Discussion
Apr 1, 2018 10:13 PM
billrodz
Oct 4, 2017 12:27 PM
santoku
Dec 1, 2016 05:20 PM
Shepper
Mar 22, 2005 09:46 AM
