20v Intake mods: Is it worth it?
After perusing various posts on the subject (my favorite being iProdrive's Custom Intake Project here) I have surmised that conical air filters provide minimal performance gains, and require further heat shielding, or else they will be drawing hotter air than the factory air box. Despite iProdrive's tenacious quest for dense air, and even a larger diameter MAF housing, performance gains were still marginal.
Now don't get me wrong, I'd love for someone to prove otherwise. I'm all about DIY improvements, as long as they are truly improvements; Of course a conical intake sounds awesome, but does one really gain power for all their effort?
How many of you have made this conversion, how much did it cost, what MAF adapter did you use, and what were your results?
My friend suggested I build a heat shield by cutting up a square, heavy-duty Rubbermaid trash can. At first I was skeptical, but the more I thought about it the more it made sense. I imagine plastic would be easier to cut, and if done right, the molded shape of the trash can could be trimmed to fit seamlessly against the body panels and isolate the intake corner from the rest of the engine bay.
This idea sounds well and good, but would it yield results?
however Im rebuilding a turbo motor, so these will be for sale soon.
3" conical air filter: is useless. why would you want to put hot air into your intake?
http://www.034motorsport.com/034efi-...f-p-19845.html
Varia; Is this kit similar to what you have? Do you use the stock airbox?
