headlight chime and alarm horn questions
Old Mar 5, 2012 | 10:40 AM
mike2112's Avatar
Default headlight chime and alarm horn questions
Hello, new Audi owner ..2001 A6 quattro 2.7 T 180K miles
just wondering if anyone has had the issue of alarm horn in trunk sounding quiet/ muted? and there is supposed to be a "lights left on warning buzzer/chime" i believe, but mine is silent, any ideas to check, maybe p.o. unhooked it ? any help greatly appreciated, Thanks
Old Mar 5, 2012 | 10:44 AM
Airbag's Avatar
probably the switch in the door latch . It is a very bad design. It should also ding when the door is open while driving , does it ? if it dopesnt its the switch . it is a waterproof push button switch whicjh is fine . But Audis crappy engineers have a cam " roll" over it so it is not a straight compresion. This action wheres out the plunger prematually. Im betting that is what it is . you can get a switch from digikey but it requires complete teardown of the assm.
The alarm horn when locking is just a wimpy whine at best . They didnt give it a long enough signal high to activate it. so it just barely wimpers.
Mine makes sound when you trip the alarm tho,, and even often during the night when you dont
Old Nov 24, 2013 | 01:47 PM
matijatic's Avatar
Default Warning sound problems
Hi, it's a new second hand Audi (A8 D3 -04 3.0 TDI quattro) owner here who has similar problems.
-> lights on warning buzzer works occasionally
-> same thing with turn signal sounds
-> seatbelt warning chime is not operating at all
--- prev. owner may have done mod on this but should there be a warning light on the cluster as well?
I've had the car only two weeks, so I have not learnt any pattern on these malfunctions. Please advise, if you have come across similar faults and if you've suggestions on mods/repairs.
Ps. What comes to headlights, up here (North EU) law states theirs (or DRL's) should be on all the time. Apparently lights can be coded continuously on even though there isn't "auto" position on light switch?
Old Nov 24, 2013 | 01:58 PM
GTA_Driver's Avatar
Tech Guru
You want the A8 forum for your D3, this is C5.
When codes out, neither the seat belt chime nor the indicator light will be on. That's how it is on the C5.
dS8
Oct 22, 2008 01:30 PM
kinderutz
Audi Original "S" Cars
Oct 25, 2007 02:44 PM
JPCady
Mar 14, 2007 03:36 AM
Crazce16-Hokie Pride
VAG-COM Discussion
Nov 22, 2005 05:41 AM
petequattro
VAG-COM Discussion
Feb 10, 2005 04:55 PM
