Checking and cleaning spider hose
i was planning to do some maintenance on my car today, I am going to do a boost leak test (after I make the plug thingy) and then remove the valves for the sai pump and install the block off plates that I ordered 5 years ago, lol. also, maybe if I get my transmission oil cooled off in time, i would go an oil/filter/gasket change...
hopefully I can get this spider hose issue fixed, I had issues with something related to the spider hose like a year ago, but then I got the updated oil cap that would relieve pressure or something, and I ignored the spider hose issue...
ohh i remember now, it was because of the valve cover gaskets going bad that I figured I had a blocked spider hose...
Biggest issue I know of about the spider hose is that it can get brittle with age and break, or crack and leak. That would be about as bad as if it gets plugged. Some folks have replaced it with standard hose, t-fittings and an oil-catch can...
Jim
My 2.7t does not do this. My oil also dirties up way quicker than on my 2.8 which is telling me my PCV on the 2.7t is either partially or fully clogged. It's on my to do list for this spring. I will probably be replacing the whole spider hose for fear of it cracking apart trying to clean it. http://www.ecstuning.com/Audi-B5_S4-...aign=postreply Price sucks but may have no choice if it is brittle.
Jim
omg, the passenger side you can get both screws in, but the driver side only 1 for the plate because its a different setup, I'll make it really tight, but I DROPPED MY ALLEN KEY! OMG, then I dropped my magnet, and then I dropped my allen socket. LIFE SUX!
I think I'll just take off the spider hose, if I can only get to the small part in the middle which is blocked by a 10000 hoses. OMG!
