$500 for a license plate light fix a6 4.2
Then just go to the Tech articles here for how to remove the inner lining panel to get at the fasteners that hold the surround in place: https://www.audiworld.com/tech/ext60.shtml
Once that panel is off, you can just look inside the holes of the trunk lid to find the nuts. I think there are 4 along the top, and maybe 3 along the bottom?
Of course, you could just remove that entire assembly and see if you can get at the wiring for the license plate lamps. I've never monkeyed with those (only the rear folgs), but $500? No.
Take it apart yourself, especially since this is so accessible and easy to do yourself.
It basically only involves bumper off & then plug & play for new part replacement.
I think my Hi horn is not working, maybe loose wire, connector.
https://www.audiworld.com/tech/ext55.shtml
So again, if it IS a wiring issue, buying the part NEW and doing the swap yourself is way cheaper.
