VIDEO: replacing the center LCD screen in the cluster
Old Apr 27, 2012 | 10:09 PM
k0mpresd's Avatar
Default VIDEO: replacing the center LCD screen in the cluster
shot this last october. posted on vortex and audizine. figured id post it here as well. any questions? ask away.
http://www.youtube.com/watch?v=T7-LXtVv_nA
Old Apr 28, 2012 | 07:16 AM
audifirst's Avatar
are you trying to promote your business or show how not to replace the LCD ? because this sounds like poor electrical skills...
Old Apr 28, 2012 | 08:50 AM
Just Me's Avatar
Tech Guru
Tech Guru
can you elaborate please?
Old Apr 28, 2012 | 09:02 AM
k0mpresd's Avatar
ok guy. youre right. im doing it all wrong.
Old Apr 28, 2012 | 09:14 AM
k0mpresd's Avatar
check his sig. he offers the same service. id like to see how he does it.
Old Apr 28, 2012 | 09:24 AM
audifirst's Avatar
I guess you don't have electronics experience how to do it .. do you ?
Those that work as repair technicians as I do, don't use table without proper ground anti-static mat, that is must, and that cluster moving around the table hmm ... I don't use screw driver to remove the old lcd...,
as electronic repair tech, I would be embarrassed to post this video
Old Apr 28, 2012 | 09:26 AM
k0mpresd's Avatar
lol. he also talks about how bad the aftermarket lcds are on the page for purchasing a single lcd then turns right around and uses them is his cluster repair service.
Old Apr 28, 2012 | 09:28 AM
audifirst's Avatar
as electronic repair tech, I would be embarrassed to post this video,
it is so badly done, the procedure and tools is not what someone would use to to remove and install lcd ..
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 28, 2012 | 09:30 AM
k0mpresd's Avatar
i work on bga stuff all day. never a problem. i work out of a room in my home. i do what i do to pay my bills. you can hate all you want. i dont care. what i do works and i have lots of satisfied customers. im not using a screwdriver either. it is only to pull up the ribbon after the hot air melts the solder enough to loosen it. i also fix abs modules, maybe you should have contacted me.
i do me7 emission deletes and immo2/3 deletes.
Old Apr 28, 2012 | 09:31 AM
audifirst's Avatar
I invested in my business, my product I use is my own product that I manufacture, but again you are getting away from post, I would be embarrassed to post your installation procedure ...
