DIY Timing Belt Questions
Old Apr 29, 2012 | 03:30 AM
lawnerd's Avatar
Default DIY Timing Belt Questions
I've decided to do the timing belt replacement myself.
I ordered the kit from Dieselgeeks and reviewed the excellent writeup on the internet but I have two dumb questions.
I got an engine support bar, where do I attach the support chain to the engine? Is there an obvious attachment point?
You have to confirm TDC at the transmission inspection hole. Where exactly is the transmission inspection hole located? Again is this obvious once I'm working on the engine?
Anyone else who has done their timing belts - any advice?
Thanks.
Old Apr 30, 2012 | 07:40 PM
pmorrissey's Avatar
If you have to ask these questions, you are heading for disaster. This is one job you should not try unless you have done it before with somebody else who knows what they are doing. One small mistake will destroy your engine. Trust me. I destroyed the engine on my 1985 Maserati Biturbo by trying to replace the water pump myself. I had the timing belt off by one tooth, and it was costly. I do almost all the maintenance on my TT myself, but last month when I needed timing belt service, I took it to the pros. This is not the place to save money. Ciao!
Old May 5, 2012 | 02:33 PM
lawnerd's Avatar
So I replaced my timing belt. It took about 10 hours but everything went well. The old timing belt looked OK but the old tensioner was worn. The transmission flywheel inspection hole is above the transmission on the driver's side of the engine. I supported the engine with an engine support bar linked to a point on the engine. However, when I had to replace the engine mount I had to jack the engine from underneath to get the alignment correct.
Overall not a bad way to spend a day.
Old May 7, 2012 | 12:51 AM
lewes2's Avatar
Nice job and congrats! I am so pleased to hear you were successful in spite of the exceptionally poor advice you received. You obviously have experience and the tool to get the job done.
So, what's next on your TT list?
Old May 7, 2012 | 03:51 PM
lawnerd's Avatar
After the timing belt, I changed the oil, changed the haldex oil and filter, and replaced the brake fluid.
Next up is new brake rotors and pads. Should be a piece of cake after the timing belt.
I love my little rat car.
Twilight Blindness
Audi allroad
May 8, 2018 11:09 PM
kchao2000
Q5/SQ5 MKI (8R) Discussion
Sep 24, 2011 11:34 AM
GreekTTCharlie
Apr 24, 2008 03:26 PM
Holographic77
Oct 9, 2007 08:08 PM
Shawn99/30V
Dec 20, 2000 05:28 AM
