DIY 94 cabriolet auto trans rebuild
94 audi cabriolet: is this possible by a reasonably resourceful do it your selfer? Any tips hints on first getting it out. Do you take out the starter to get to the flex plate/torque converter bolts. Also any tips or sites that go through the rebuild process. I've done just about every form of rebuilding other than an auto trans. I'm not too old to learn!
thanks, for any help, tips and advice, hushpuppy
thanks for your input. good luck on the std trans swap.
hushpuppy
here is a view of the Trans with the engine removed...
the starter goes in the little indention about 8 o'clock on the flex plate. with the starter out you can rotate the crankshaft and remove each nut.
From what I understand, a manual swap is possible without changing the ECU but you have to do some things to trick it into starting without being in park.
The FWD axles from a manual are different than FWD from an auto so I need to source them.
i dont know the quality of them as ive just installed them... but, they do come with a life time warranty, so that's a pluswhat about OBD2 cars? do you think its the same trick with the ECU?
i might be doing a conversion for a friend, hes got an OBD2 cab, so trying to find as much info as possible before i get myself in to this
You have a FWD too? I thought your B4 was a Quattro.
I'll check out the axles. The CV joints are the same I think
Here are the threads I've tagged for help so far...
https://www.audiworld.com/forums/sho...php?p=18179420
https://www.audiworld.com/forums/sho....php?t=2802522
https://www.audiworld.com/forums/sho...php?p=18175274
http://forums.quattroworld.com/a4/th...27.phtml#46844
