No brake lights, but brake switch OK
Old Oct 24, 2012 | 04:52 PM
Loudgoldwing's Avatar
Default No brake lights, but brake switch OK
Hey guys, my PC needed a wipe and clean recently, and I haven't re-installed my ElsaWin yet. I need help, please.
If I press the brakes and there's no brake lights, and the car won't shift out of park, I need to change the brake light switch, right? Well, that's what I did...
It didn't work. Both switches test perfectly, but no luck. I even jumped the plug connection to the switch to make sure. Nothing.
Recently, when I put the car in park and took my foot off the brake, the shift lock solenoid would cycle on-off, on-off. I also heard a ticking (in rhythm with the solenoid) coming from behind the dashboard on the left side of the steering wheel. When I put my foot on the brake, the noise stopped. So I turned off the car, I got down under the dash and wiggled the brake light switch, and the issue went away.
A few days later, no brake lights, and no shifting out of park. Thank God the car was in my own garage, and not at work.
Is there a block relay for the brake system that might have fried? Or maybe a fuse that blew? That's about the only thing I can think of that would do this, other than the switch.
Old Oct 24, 2012 | 05:21 PM
Default Found the problem...
10-amp fuse for the brake lights had blown.
The driver's brake bulb had blown, and the filament was drooping, causing the filament to also close the circuit. It was actually a short in the bulb itself.
I swapped the fuse and it blew immediately. I checked the bulbs, found the problem described above, pulled the bulb out, and a new fuse fixed the issue.
LaserSVT
RS 6 Discussion (C5)
Jul 22, 2022 10:29 AM
jjcuff1
A6 (C7 Platform) Discussion
Sep 8, 2015 12:02 AM
DannyG123US
Sep 7, 2015 05:53 PM
stormchaser1967
Sep 2, 2015 09:26 AM
Beena
A4 (B8 Platform) Discussion
Sep 2, 2015 12:01 AM
