Crankshaft removal tool
Old Oct 28, 2012 | 10:36 AM
Quinton Carlson's Avatar
Default Crankshaft removal tool
I need to pull the timing gear and harmonic balancer so I can replace a leaky seal. I have the front end tore down now I need a VAG 2084 tool to remove this bugger and no one has one of course and my dealer is closed and two hours away at that. I am wondering if anyone has had luck with any universal tool or any other suggestions someone might have for removing the harminc balancer and gear.
Thanks
Old Oct 29, 2012 | 07:37 AM
CRAZY_RUSSIAN's Avatar
if you are working on a B4 12v V6... which btw i have no idea because you didnt mention what car you are playing with! you have 6(or 8, cant remember) alen head bolts to remove the H.B. then you have another bolt to remove to get the T-belt gear off. after that, use a wood screw to get the seal out, or a seal puller. if its a B3 with I5... i have no idea
LoPan455
A4 (B7 Platform) Discussion
12
Aug 21, 2019 07:48 AM
T1no33
Audi A3 / S3 / RS 3 MKII
14
Feb 9, 2019 01:55 PM
craigandjenn4
Q5/SQ5 MKI (8R) Discussion
Sep 27, 2015 01:57 PM
live2tune
Sep 24, 2015 10:35 AM
