Audi 90 Fan belt slipping on AC
Old Oct 30, 2012 | 06:18 PM
Dkat1's Avatar
Default Audi 90 Fan belt slipping on AC
I smelled burning rubber so i checked under the hood and noticed that the fan belt was slipping on the ac, while the ac pulley would move a little than stop then move then stop etc... But i noticed when i turn the fan on for the ac/heat inside the ac pulley moves freely......whats going on? help!
Old Oct 30, 2012 | 07:13 PM
Loudgoldwing's Avatar
Your A/C Compressor clutch is shot.
When your A/C is off, that pulley should spin freely. It is seized, and wanting to spin the compressor, even when the A/C is off.
Old Oct 30, 2012 | 07:43 PM
Dkat1's Avatar
Okay does that mean i need a new compressor? do i need special tools for anything
Old Oct 30, 2012 | 07:52 PM
Dkat1's Avatar
also any instructions on how to replace the compressor( if thats what i need to do) special tools, how to get the belt off, etc...anything helps thanks..
Old Oct 30, 2012 | 11:03 PM
CRAZY_RUSSIAN's Avatar
you can just get a belt that doesn't go thru the AC compressor. you might be able to replace the ac clutch, but most of the shops will just replace the compressor in that case. if you do decide to replace the compressor, i would recommend vacin the ac system first, then pull the compressor, replace the o-rings, install a new compressor, recharge ac.
Old Nov 1, 2012 | 05:51 PM
Dkat1's Avatar
how do i know what size belt to get if i want to eliminate the compressor? and how difficult is it to take the belt off...Special tools?
G_claudz
Sep 15, 2015 10:47 AM
jared8783
Sep 9, 2015 08:18 AM
Yoshimura
Q5/SQ5 MKI (8R) Discussion
Aug 31, 2015 09:08 PM
Janryk
Aug 30, 2015 02:12 AM
Kris Hansen
A4 (B7 Platform) Discussion
Aug 27, 2015 06:45 AM
