Axle bolt torque
The bolts that I got with my new wheel bearing kits are a 17mm female hex (allen) that is threaded all the way up the w/ a 1/4" shank at the top.
After doing much searching I have come up with the following specifications found on the forums:
90 ft lb
147 ft lb
200 ft lb
200 ft lb + 1/4 turn (hmm..
)200 ft lb + 1/2 turn (yeah right
)86 ft lb + 1/4 turn
86 ft lb + 1/2 turn
Apparently, someone on the forums claims the Bentley manual says:
86 ft lb + 1/2 turn
And, finally, my copy of ElsaWin says:
81 ft lb + 1/4 turn
So does anyone have a definitive answer? I really want to make sure that I am torquing to the correct value, so hopefully these guys will last longer.
-Thanks
