charging circuit diagnostics
Old Feb 10, 2013 | 05:18 PM
Solid20vq's Avatar
Default charging circuit diagnostics
When I jump the car, the aux gauge voltmeter reads 12.6-13v steady. As soon as cables are removed, gauge reads 12v or less; volts increase minimally with rpm, but doesn't maintain voltage as loads are added. Multimeter reads 12.3ish on the battery, while car is running, and a variable 11.9-12.8ish volts on the alternator, with load or without.
I'm guessing its the alternator, what do you think?
Old Feb 10, 2013 | 05:54 PM
socalclimber's Avatar
Default check alternator exciter circuit and ALT dash light
Originally Posted by Solid20vq
I'm guessing it's the alternator, what do you think?
Alternator indicator light in dash MUST illuminate with ignition in ON position, and go out once engine is started. Does it?
If indicator light does come on with ignition ON, and goes out with engine running, yes, I would say alternator is bad.
Alternator will not charge if this exciter circuit has a problem or indicator light is burned out.
I can scan diagnostic page from Bentley, if you need these details.
Old Feb 11, 2013 | 07:46 PM
x19's Avatar
x19
Probably, brushes on Voltage Regulator worn out or may need to replace the alternator,
Old Feb 12, 2013 | 12:45 AM
Solid20vq's Avatar
So I replaced the alternator, yet the same symptoms persisted. Multimeter was reading out at least 13v output on the alternator. Aux gauge inside was only reading about 12v though. Eventually the car died, and emitted an electrical-smelling cloud of smoke from the front of the engine. I had perfect continuity between the alternator and the battery though... guess its time to rip apart the harness?
darussell
Aug 14, 2017 07:00 AM
Golds
Feb 21, 2015 12:31 PM
MrFine
Oct 19, 2007 02:08 PM
Ben's e//S2
Jul 12, 2004 07:01 AM
bowdinh
Aug 25, 2003 10:28 AM
