2004 S4 4.2: cooling fan, after run pump running
No electrical gremlins remaining:
- sometimes electric coolant fans come and stay on (car locked)
- humming noise (from afterrun coolant pump (driver side, engine bay) ??)
I ran output test with VAGcom, afterrun pump comes on, turns off (noise gone) for a few seconds, but shortly after starts again.
I don't see any codes providing a hint. Full scan below. ABS steering angle sensor code disappeared as usual after a bit of driving.
Also (always was this way), codes from mismatching VIN numbers. Can this be fixed?
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Saturday,14,June,2014,16:32:00:36008
Chassis Type: 4B (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WA1YL64B15N000702 Mileage: 263340km/163631miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 A HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0007711
Shop #: WSC 25061 444 01427
VCID: 2345571DE1595006A65-5124
No fault code found.
Readiness: 0010 1100
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04595
Shop #: WSC 06435
VCID: 36639E4912CBD5AE71B-5106
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 00000
VCID: 63C5171DF1D91006E65-5124
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 03317
VCID: 356199450FCDDEB6781-4AEC
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 A
Component: SDAR XM 0010
VCID: 275D430DC561BC26FAD-5076
1 Fault Found:
00003 - Control Module
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 3001
Coding: 0010607
Shop #: WSC 03317 444 84819
VCID: 377D934D45C12CA66AD-5106
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 03317
VCID: 3E7386693AFB1DEEA9B-4AEC
1 Fault Found:
00532 - Supply Voltage B+
53-10 - Supply Voltage Too Low - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 980 M
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 01231
Shop #: WSC 03323
VCID: 36639E4912CBD5AE71B-5124
Subsystem 1 - Part No: 03202
Component: AUZ6Z0C0249450
03202 AUZ6Z0C0249450
1 Fault Found:
01302 - Control Module for Telematic (J499)
49-00 - No Communications
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: F1E9ED55BB253296E49-4AEC
2 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
35-00 - -
Address 37: Navigation Labels: 4B0-919-887-BNS4.lbl
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
VCID: 356199450FCDDEB6781-4AD2
1 Fault Found:
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11788
Shop #: WSC 63351
VCID: 72EB62593E23898E9D3-4AEC
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 040734811497B73EBFF-4B1E
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0400
Coding: 01230
Shop #: WSC 73472
VCID: 2C57BC21DC879F7E17F-5076
2 Faults Found:
01303 - Telephone Transceiver (R36)
49-10 - No Communications - Intermittent
Address 75: Telematics Labels: None
Part No SW: 8E0 035 616 A HW: 8E0 035 616 A
Component: Telematik USA1
Coding: 0005033
4 Faults Found:
01656 - Crash Signal
004 - No Signal/Communication - Intermittent
01300 - Control Module for Navigation with CD-Rom (J401)
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
002 - Lower Limit Exceeded - Intermittent
End ---------------------------------------------------------------------
