S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
4.2 allroad problems, thought yall might be able to help...
Old Jan 19, 2015 | 02:42 PM
Pig In a Poke's Avatar
Default 4.2 allroad problems, thought yall might be able to help...
Is this a Cam adjuster?
I bought the car and it started on my way home of course...
This noise is intermittent but occurs cold and at temperature. I have had missfire issues as well and have replaced the sparkplugs and coils, swapped injectors from one side to the other and still have the same misfires detected.
Address 01: Engine Labels: None
Part No SW: 4D0 907 560 DC HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Revision: 00000000 Serial number: AUZ7Z0D2695394
Coding: 0007755
Shop #: WSC 02334 785 00200
VCID: 6ADBF1D1466D6971D1F-5140
5 Faults Found:
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean
16558 - Fuel Trim; Bank 2
P0174 - 001 - System Too Lean - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16685 - Cylinder 1
P0301 - 001 - Misfire Detected
16687 - Cylinder 3
P0303 - 001 - Misfire Detected
Readiness: 0110 1101
Thanks
Old Jan 19, 2015 | 05:16 PM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
The misfires stay with the cylinders? You are referring to that intermittent clicking as the noise? Never heard anything like that..
Lean running usually is a vacuum leak or an intake leak..
Old Jan 20, 2015 | 02:24 PM
Despite moving the injectors, swapping the four lefts with the four rights, I still had misfires at cylinders 1&3. I will continue to look for vacuum/intake leaks.
codyrhodes1999a6
Aug 24, 2017 03:30 AM
thedoc456789
VAG-COM Discussion
13
Mar 15, 2010 05:26 AM
pkvoss
Jan 31, 2009 05:49 PM
cwh
NY / NJ / CT Discussion
Jan 14, 2006 10:30 PM
mpwolf
17
Jul 15, 2003 09:48 PM
