Educate me: A/C low side adapter
What I don't get is what happens to the low pressure switch when I'm done charging my system. Does it get left out permanently? If it gets reinstalled, how is that done without losing a bunch of r134a?
What piece of the puzzle am I missing?
Regards... Mike
1993 100 CSQ
For clarification, when you say that the adapter has a spring-loaded valve in it, do you mean the port that the switch is currently screwed into? Should I be able to remove the switch from that port without losing any appreciable amount of the refrigerant that is residing in the system?
Thanks... Mike
1) remove sensor wiring
2) remove sensor (16 mm)
3) check condition of O-ring - any cracks/tears or if hard/not-pliable, replace. It seals the sensor or adaptor so it needs to work properly.
4) make sure center pin of adaptor moves freely. If so, screw on adaptor and snug to make seal (mine, annoyingly uses a 17mm wrench, not easy to fit and not easy to find as a flare nut wrench.
5) jumper sensor cable
6) charge per refrigerant directions
Assembly is the reverse of removal (a little Bentley humor).
