Coolant leak 93csq
This occurs about 5 minutes after warm engine shutdown, not when it is running.
No coolant odor is detected from the cabin vents nor is there visible evidence of leakage in the cabin. The HVAC bay is completely dry as well. I don't think it is the heater core.
Where to look? After things cool off I'll attempt to remove the plastic plenum (that "V6" thing that connects to the throttle body) and try to see down there, but access looks pretty tight.
Any tips and suggestions from those who may have been down this road would be quite appreciated.
Regards...
Mike
Update: I changed my mind... now I think a leaking heater core is possible. I found no leaks in the area of the backside of the engine. Besides, the drips are farther back than that. I hesitate to rip the core out unless I know for sure that is the problem... I'm just not seeing enough evidence of it.
I'm going ahead with replacing the core (and blower while I'm in there). It's not as difficult a job as I had imagined... just a bit time consuming.
Thanks... Mike
https://www.fcpeuro.com/products/aud...alve-4a0819809
