Fault codes
Old Oct 4, 2015 | 05:22 AM
phoneboy6's Avatar
Default Fault codes
Hi all,
I scanned my 2013 a7 and see some fault codes. For now and the future, how do I found out what the codes mean? Is there a website or something I can put the code in to tell me what it means. Thanks
Old Oct 4, 2015 | 08:49 AM
Mrclopec's Avatar
Tech Guru
Here's a start:
Category:Fault Codes - Ross-Tech Wiki
Old Oct 4, 2015 | 10:51 AM
snagitseven's Avatar
Super Moderator
Keep in mind, if everything is working properly, sometimes a fault code from a scan can often not be a real problem. I've found a few from time to time on my scans that my dealer's senior service tech attributes to occasional sensor anomalies yet all systems are fine when checked out. He sees these mystery fault codes all the time.
Old Oct 4, 2015 | 12:03 PM
tenspeed's Avatar
Fault codes that do not turn on the check engine light are known as pending trouble codes. When the program sees a pending code often enough, it turns on the CEL. If the light came on every time a sensor was out of range, the light would be blinking all the time and soon ignored.
Old Oct 4, 2015 | 01:13 PM
Super Moderator
Every time I scan the car since new, I show a fault code on the list for the sunroof with something like "temp out of range". The sunroof has always worked fine for over three years. When I first pointed it out to my tech, he said he's seen that one come up frequently but is not a problem, just an overly sensitive sensor and not worth worrying about. I don't.
Old Oct 4, 2015 | 02:16 PM
phoneboy6's Avatar
Thanks for the info folks. Mine had to do with adaptive cry sue control.
Old Oct 4, 2015 | 02:38 PM
Mrclopec's Avatar
Tech Guru
What code is it giving?
Old Oct 4, 2015 | 08:35 PM
Super Moderator
It could be one of the ACC sensors in the grill is covered in road gunk, out of alignment or has failed.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 4, 2015 | 09:51 PM
exotich's Avatar
Did you have a crying sue in the car?
Old Oct 6, 2015 | 03:42 AM
phoneboy6's Avatar
The fault codes are below. I was not able to find them
Adaptive cruise control:
10496
152320
If anyone knows what they mean, I would appreciate it. Thanks
CPLYONS
Sep 3, 2015 07:04 PM
Flats
Jul 13, 2015 11:23 AM
calfalfa
Q7 MK 1 Discussion
Nov 19, 2014 08:12 AM
ssingh
Feb 27, 2013 02:54 PM
SilverSchwinn
Nov 20, 2006 07:04 PM
