Bentley manual- valve lifter section
So in prep to change lifters in my A6 (AFC SOHC), I picked up a bentley. In reading the section on lifters, it says the following:
"After installing new or re-installing old lifters, and after installing the camshaft(s), the engine must not be started for at least 30 minutes. Otherwise the valves could strike the pistons."
I'm not sure why this is in there, or if it is valid. What is the 30 minute wait going to accomplish? I can of course see an issue if the timing is off, etc, but what is the wait for?
I haven't see this mentioned in any of the videos/write ups I've read so far..
Thanks-
Brady
Never seems to be a problem on VAG lifters in actual practice..maybe because it takes a while to button up the valve covers, pulleys and timing belt, giving the lifters plenty of time to reset once installed.
Where do you order new lifters, I have a 1992 Audi 100 that I just bought with 123k miles...have a pic of it on my profile
https://www.fcpeuro.com/products/aud...er-034109309ad
Do double check the vendor part number and the OEM part number when ordering the lifters..most people do not know. FCP lists the INA part number and it looks correct. Check again when you get the actual parts too.
https://docviewer.yandex.com/?url=ya...c=57a487610042
If the car has been sitting a while..it takes some time for the lifters to "pump up" almost an hour driving around sometimes.
Be sure the oil is fresh and the oil filter is a good German made Mahle or Mann oil filter.
The aftermarket filters can cause problems
Lifter replacement? or should I look at changing those oil pressure switches that are in each valve cover and the valley?
It really takes an hour? How long is a while, not like overnight right?
This car is near mint, just the lower external door trim is coming off on both sides...
Get a German oil filter..do the oil service and drive the car for a hour or two.
That usually works getting the lifters to quite down.
