Timing belt time 😑
probably an 8-10 hour job if you pay attention to instructions - you'll make it fine.
Clearly make your timing marks, pay attention to when you need to put the lower engine mount back in (before installing new water pump - it does not go in after like i did - had to pull new water pump back out and then put engine mount in - and then reinstall water pump.
Got the opportunity to clean off engine pretty well - nothing like 13 years of oil, and road crap off the bottom of engine. I am sure it will run faster now
