Dash - fix ideas for temperature speedometer & fuel gauge
1. Temperature gauge moves but maintains a very constant position 1 mark shy of 'H' when regardless of warmed up or not (see picture).
2. Fuel gauge moves but is wrong, however number of miles left before fillup on the LED display is correct!
3. Speedometer reads about 8mph too slow compared to actual speed (maybe a little less at lower speeds I couldn't quite tell but certainly true in 50-70mph range)
Possible Solutions:
After scouring the forums and other forums too i've come up with this:
For #1 Temperature Guage) Thanks to JustJeff's very nice DIY cluster repair write-up it appears fairly clear that he replaces the guage movements aka "stepper motor" as they are what go bad in these clusters. I found Tanin Auto has them for $25. Does anyone know of any other electronics distributor that sells the movements / stepper motor for cheaper? Of course you can also send it to bba-reman.com for ~$300 and have your original fixed (most likely the same fix) if you are not so inclined to DIY.
For #2 Fuel) Here, though it looks like the same issue might fix it there also may be an alternative cheaper solution. This fix in the ttforum.uk might be the just what i need and you just have to adjust the needle and shave down the rim to ensure it doesn't bonk into the rim!
For #3 Speedometer) Could this be a stepper motor replacement like #1, or is there something else maybe wrong bigger wheels? or a measurment issue? I'm not sure on this one, any suggestions are welcome but it is the least important of the three (IMO).
Audi TT Mk1 instrument cluster guages with various issues but no bad pixels as far as I can tell.
Module Master offers two repair procedures. Tanin also offers repair service as well as parts sales at very reasonable prices.
Here is the link to our service which is $149.99 and offers a five year warranty:
Audi A4 A6 S4 TT Allroad Gauge Cluster Rebuild
The full rebuild is applicable for 2000 - 2006 Audi TT only which includes four brand new needle motors, a new LCD screen, and is $99 more.
Let us know if you have any questions. We are always happy to help our AudiForum friends!
Thanks,
I don't see this being mentioned under any other thread or mentioned in the things to fix when it gets sent in for rebuild. Anyone else have a problem with Time and date not showing up at all and find a solution?
Is there a fuse
Is there a fuse
