ABC V6 60-2 trigger wheel
Old Dec 4, 2016 | 12:01 PM
GillyBot Gilly's Avatar
Default ABC V6 60-2 trigger wheel
Hi to all i got a Audi 2.6 v6 ABC got it with no ecu wiring all wrong so i want to put a after market ecu with a 60-2 crank trigger but my problem is the tdc part it should be at no3 on top so do not know if i can line my wheel on that tdc or should i do it at no1 or where should i check my timing from no3 or no1 with the timing light please help thanx in advance
Old Dec 5, 2016 | 05:44 AM
Rusty Spokes's Avatar
Gilly..that is a tough question as you are going where no man has gone before..
My opinion..it does not matter if TDC is #3 or #1 as long as the firing order is correct. #3 becomes #1.
Old Dec 5, 2016 | 09:28 AM
Thanx for the reply and on top of that it is a open source ecu called speeduino http://speeduino.com/wiki/index.php/Speeduino haha
Old Dec 19, 2016 | 09:59 AM
Hi all does anybody know the wiring diagram of the coil pack there are Black&red Black and Black&brown then Yellow&red Yellow and Yellow&blue
Old Dec 19, 2016 | 04:13 PM
http://12v.org/urs/1997_Audi_A6_Syst...g_Diagrams.pdf
Check page 36 on the PDF and see if it helps.
Old Dec 20, 2016 | 02:06 AM
Thax that is great
