Do i have thermostat issue or waterpump
Old Feb 9, 2017 | 02:47 PM
nick greene-killam's Avatar
Default Do i have thermostat issue or waterpump
2002 audi quattro a4 1.8turbo dont see water circulating in resivor and heater only blows cold air
Old Feb 9, 2017 | 04:06 PM
J. Patterson's Avatar
Does your temp gauge stay on cold? If so, It has to be thermostat. Car will overheat if water pump is bad.
One qualification. Is this a really recent problem? Is it REALLY cold there? Is there enough antifreeze in the coolant?
Old Feb 9, 2017 | 05:05 PM
Mister Bally's Avatar
Water doesn't "circulate" in the expansion tank, if that's what you mean by reservoir.
After engine running for 15 minutes while driving; is the coolant hose from the top of the radiator hot? If so, good. if not, a blockage or thermostat issue.
If good in previous step, Inspect heater control valve for proper operation. Scan with VCDS. Repair as necessary.
scarmonasven
May 9, 2016 08:25 PM
cu52
Oct 31, 2009 09:43 PM
MonkeyMadness
Oct 30, 2007 06:45 AM
eCoastAudi
12v V6 Discussion
Feb 7, 2007 08:04 PM
DrRings
Jul 1, 2003 06:32 PM
