Audi TT wont start tried everything
I am not getting the fuel pump priming but it works fine if i hook up 12volts direct to it.
I am not getting any spark the last time i checked (but will check again)
I have replaced the crank pos sensor so that is brand new.
i have changed the ECU. Made no difference.
I can not get any communication from Vagcom
Relays are all working
Ecu seems to be getting 12volts from the pin on the connector (left hand side connector if looking from engine bay)
when you turn the ignition on, I do not have a check engine light come on then go off. It does not appear at all.
I have traced wiring back from relay that controls ECU and everything looks okay. I have taken the batter tray out and checked all grounds.
I don't know what to check now and I am now at the stage where a perfectly good car will probably just be scrapped.
Any Ideas? anyone
The guys over at ttforum were helpful but tried everything they suggested and no result
Thanks in advance
A car hauling trailer is cheap to rent for a day.
If that tests good, he will likely replace the ECU. Dealers usually have a test ECU to temporarily install in an attempt to start a dead vehicle.
Any Ideas? anyone
Thanks in advance
Any solution??????
