yet another key fob question
Old Feb 13, 2017 | 09:24 AM
vtk3b's Avatar
patient idiot
Default yet another key fob question
I have a 2001 225 roadster and have been trying to get the keyfob working.
I have a single key, and a switchblade key.
I've been through every variant of insert key, push button, etc. Got so desparate, I tried the "two bucket" method suggested in another thread https://www.audiworld.com/forums/tt-.../#post24842487
Went to independent mechanic I use for all other cars and tested remote - and it's sending a signal.
Used VAGCOM to go through the adaptation, and it does not even seem to recognize the remote. Everything else in the CCU works- door locks, trunk, gas cap, etc. So is it possible that only the receiver circuit is bad? Or maybe a loose antenna? Is there a VAGCOM screen for this? The module does not report any error codes on central locking.
FWIW - Owned the car for a few months and the PO had not used the remote for a while. Said battery died and had not bothered with a replacement. Maybe the system had failed for him?
Old Feb 16, 2017 | 06:31 AM
vtk3b's Avatar
patient idiot
I looked at the reading a little more, and the CCM was coded to 15884, which does not appear to be a valid code for the TT, even though everything worked (other than the remote).
Changed it to 15900, hoping for improvement. No luck. Everything but the remote still works.
Rocket3004
Apr 5, 2026 09:45 AM
kjmiles
Mar 3, 2013 12:29 PM
Farb
Jan 27, 2009 10:34 AM
A4orce84
Feb 11, 2005 08:14 PM
Outlaw
Feb 12, 2004 08:19 AM
