Interesting issue nobody can figure out
Old Mar 27, 2017 | 09:04 AM
quattro12v's Avatar
Default Interesting issue nobody can figure out
Hello,
I purchased a 1998 A6 Avant Quattro C4 chassis back in December.
Gave me no problems besides the usual worn suspension parts and misc general maintenance items.
On Friday I took it out for a quick spin, when I came back home I saw that it is very hard to put into Park. I would almost have to force it up. The car would think its not in park but would lock the wheels like its in park. I left it as is and then i drove it for 50 miles round trip. Got back home now it doesnt go into park at all! It shifts into reverse and gets blocked right before the stick turns left to park.
The funny thing is everything drives fine, gears shift fine. The only thing is that it doesnt go into park. Almost seems like something is lodged in there.
Anyone have any similar issues? I am not sure what to do anymore. I have to leave it in neutral and put a brick under tire when I park. The only way I can get the key out is by tapping the pin inside to release the lock.
Any advice and help is greatly appreciated.
Thank you!
Old Mar 27, 2017 | 09:45 AM
Rusty Spokes's Avatar
Is the gearshift indicator on the dash indicating correctly? The bulbs inside are probably not working..look carefully. That will tell you if the multi-function switch on the transmission is working.
Could be your shift safety interlock cable is out of adjustment..it goes between the ignition switch and the shift inter-lock.
OR..a coin (something like that) has dropped into the shifter..and blocking your PARK position.
Do your brake lights work? If not the shifter safety will not think your foot is on the brake and may not go into park.
Be sure the gear shift shaft goes up and down..with an internal spring..if not it may be sticking and need some lube.
Old Mar 27, 2017 | 10:14 AM
quattro12v's Avatar
On the gear indicator it lights up them all except P. it stays in R when going to P.
Brake lights do work.
Everything functions as it should except it going into park.
I did find the two golden screws under the wooden cover lose, I read these are the cable adjusting screws. Am I correct on them adjusting the cable?
Old Mar 27, 2017 | 01:39 PM
Could be your problem..see the attached link for adjustment
File Type: pdf
Old Mar 27, 2017 | 01:46 PM
quattro12v's Avatar
Oh wow, thank you! I will send this to my guy. After all the reading and researching its all pointing to something being stuck or lodged in there. The shop the car was at was telling me the mechanic couldnt get it out of park he had no idea you have to press the shifter down. Maybe they cracked something which later broke and lodged.
If anyone else has any input please chime in.
Thank you!
Old Mar 28, 2017 | 11:53 AM
quattro12v's Avatar
So the problem was solved. Turns out it was about $.70 in change who is responsible for this. So glad it was nothing serious.
Nikon1
Audi A5 / S5 / RS5 (B9)
26
Mar 9, 2019 02:26 PM
Chris2289
Sep 16, 2018 08:57 AM
Joshua Kwon
Mar 8, 2016 12:16 PM
chromatin
Nov 3, 2007 06:08 PM
everest29
Oct 23, 2006 10:51 AM
