Error in the instrument cluster
Old Jun 19, 2017 | 03:54 AM
Sampinjons's Avatar
Default Error in the instrument cluster
Hello,
I hope someone can help me. Recently coolant temperature gauge and fuel level gauge stopped working at the same time + clock only works when the car is running. All warning bulbs, speedometer, voltmeter and tachometer are working fine. I already checked the wiring and didn't find anything suspicious. How I can check if the voltage regulator, stabilizer/regulator are working correctly and where I can find these components?
Audi A6 Avant (C4), 2.5 tdi, 103 kW.
Old Jun 19, 2017 | 08:21 AM
Rusty Spokes's Avatar
See if this helps? quattroworld.com Forums: Towards replacing the instrument cluster clock with another gauge.
And the PDF too..
File Type: pdf
Old Jul 1, 2017 | 11:36 AM
Sampinjons's Avatar
Thanks Rusty for schematics. The problem was in the fuse. I replaced the damaged one, but the fuel level gauge probably is not showing the correct level anymore.
darkix10
Dec 18, 2016 08:15 AM
erojan83
Sep 22, 2013 10:59 AM
jkerr
Jul 11, 2011 08:33 PM
jayel
Apr 28, 2006 08:08 AM
cuch80
Sep 18, 2002 03:47 PM
