Error in the instrument cluster
Hello,
I hope someone can help me. Recently coolant temperature gauge and fuel level gauge stopped working at the same time + clock only works when the car is running. All warning bulbs, speedometer, voltmeter and tachometer are working fine. I already checked the wiring and didn't find anything suspicious. How I can check if the voltage regulator, stabilizer/regulator are working correctly and where I can find these components?
Audi A6 Avant (C4), 2.5 tdi, 103 kW.
See if this helps? quattroworld.com Forums: Towards replacing the instrument cluster clock with another gauge.
And the PDF too..
And the PDF too..
darkix10
12-18-2016 08:15 AM
erojan83
09-22-2013 10:59 AM
jayel
04-28-2006 08:08 AM
cuch80
09-18-2002 03:47 PM
